My TBI setup has an aftermarket harness with two relays located near the ECM. I'm not entirely certain the function of both relays. One of them is surely the fuel pump relay. The other may just be keyed +12, so any keyed source can be used to trigger the relay and then the ECM can feed off of the same "always on" source. It's been a while, but I think the harness is only fed by a single +12 source from the battery. Does this make any kind of sense? Does the factory setup have a power relay in addition to the fuel pump relay?
