My truck (in sig) just developed a bad stumble on acceleration. Unless I accelerate very slowly, it coughs and stumbles and wants to die. It's OK at steady speed, but not great. The TBI and engine are stock. I ran a datalog with WinALDL and the only thing that stood out to me were a bunch of rich flags. No codes were set (other than 12). The O2 reading is switching from 0.1 to 0.9 normally.
I did have the steering column out just before it started acting up, and now the brake light is on (and no, the e-brake isn't on, I don't have one). Could I have knocked something loose that would cause the stumble?
Also, I've noticed the fuel pump running for up to 30 seconds or so after I shut off the truck (key out). I assume it runs to keep pressure in the lines for the next start. The pump is running noticeably longer than it used to. Could I have leaky injectors or something?
I'll probably borrow Kjunky5's fuel pressure gage next weekend to see if that shows anything interesting.
Any other ideas?
Any other ideas?
