k5Thumper
Registered Member
hello, got an 88 k5 TBI 350 that has an occasional miss, especially at idle. It’ll stall out when I get home from work and put it in reverse to back into the driveway. Has new o2 sensor, fuel pump, cleaned and rebuilt TBI (same injectors) and new tps sensor. Has newer plugs/wires/dist and vac lines look solid. Is there something obvious I’m missing? Thanks
