RaysJimmy
more Only thing missing would be knock sensor, broke while I was moving engine. Trottle body, distributor, air cleaner housing, coolant temp, egr, intake(if you need it, it will add weight to the shipping) wiring harness, computer, fuel lines, etc, etc. Was running before I took apart. $250.00+ shipping. Figure shipping from 90670 zip. If you want the intake manifold, you will need a thermostat housing. Serpentine set up $100.00 with or without all the accessories, no smog pump. (water pump, pullies, alt, belt, power steering pump, brackets and bolts.
