robert97dodge
I have a TBI set up that I am gonna try to sell if i can get it sold before this other guy sells some parts I need. It came of a 350 motor. It is the wiring harness, computer, distributor, coil, throttle body with adapter plate to bolt onto 4 bolt intake, and it looks like all the sensors are there too and I will include a fuel pump that I got with the set up but I dont know if it works or not. Also I have a VERY good wiring diagram of this set up that tells you exzactly what each wire is and which ones should get power and which ones are hot. I will include that too to make wiring a bit easier. I would like to get $300 shipped to the US.
I also have a MSD pro billet distributor part # 8366 I actually just purchased this but I could use to money for some other stuff. Distributor, Pro-Billet Ready-to-Run, Magnetic Pickup, Electronic Advance, Chevy, 5.0/5.7/7.4L. It is brand new in the box and I also have a MSD coil part #MSD-8226 that goes with the distributor. Ignition Coil, Blaster Performance Replacement, E-Core, Square, Epoxy, Red, 48,000 V, GM Distributor and coil both are brand new in box. I also have a MSD box I am pretty sure it is the 6A I will have to check. I bought it used and had it on my '01 dodge but I took it off last november when I sold the truck. I will sell it with the distributor and coil for a total of $500 shipped.
Also have a MSD coil pack for a 94-01 dodge ram not sure may also fit other years. I bought it used and had it on my '01. $40 shipped for it.
