shadowwalker_02
I search the forum and found one thread and I didn't really find what I was looking for by googling all the ls forums.
So my question is what all do i need to do to swap from a SBC tbi to a BBC carb'd? From what I have read there are several ways. To keep it simple I want to do it the easiest most painless way.
1. use existing tbi sending unit in tank and put a pressure regulator on it down to 3-5lbs for the carb and run a return line to the tank?
No with this way what is the best way to go about doing it? I know I need to run the fuel sender in the tank to a wire thats hot with the key on. Where would I put a fuel pressure regulator on? I haven't messed with one before. As for the return line, would I just use the existing one and re plumb it or? Is there anything else I need to do for this swap? I allready have the tci lock up kit so no worry there.
One other thing. My buddy stated his opinion that i could completely bypass the tbi unit in the tank and just make do with the edel fuel pump I have now. I don't think I can do that but why couldn't I? Is there anything else I am missing for this swap?
