I installed one on my Suburban a few months ago... might have been last summer even. In my case, I got the Jegs model, which is just two holes, no cutouts. Longer intake runners can help low end torque, bouncing the air fuel mix off the blades of the throttle body etc. Anyway, I noticed a big difference in low end performance in my rig. It probably helped push the 35" tires with 3.73 gears better. I always keep track of fuel mileage; no change better or worse after installation, but more power with no change in mpg's? I'll take it!
I also installed a salad bowl from Jegs. Cheap, and maybe it helps. Still have the injector pod spacer to install as well. Again, cheap, if it works, that's cool.
Yesterday I hauled quite a bit of wood, with a nice hilly drive home. I am still pleased with the fact that I can still keep up with traffic was fine even while going uphill with a load like that. Stopping however is another story. Thank goodness for gears!
Good luck with your decision. I say go for it!
