samsterman99
Got my TBI Swapped in. The chip is for a manual transmission, so I plan on making my 700r4 lockup internally with the wiring. I have everything wired up except for the crank sensor (seems to not be necessary for the moment), the P/N switch (doesnt matter since its a manual), the EGR and the other emissions stuff.
Starts up quick, idles @ 1300 and then about 800 when warm. No codes until at high way speeds and light throttle, code goes on and off, I assume its the EGR code being set.
One problem I have is with the Idle, IAC, and setting base idle. I have jumpered the diagnostic terminals, unhokked the IAC after 45 sec, and then started the car and the idle is at 2500 RPM's.... How is this possible?
The only other problem is at low RPM's and about 1/10th throttle off idle, the car seems to go flat and bog, and after 2 seconds the car gets back on its feet and runs fine. Or if I increase the throttle the problem goes away.
I sprayed ether around the TBI base gasket and the car died and stumbeled. So I assume I have a vaccum leak and need to get that sorted out first.
Could all these problems be connected to a vaccum leak? It doesnt seem like a major leak, but I could be wrong.
Also, is leaving the manual EEprom in there a bad idea? Or will it just run fine since I am not going to use the ECU to make the lockup function.
