kauzenkaos
i recently swapped a built sbc long rod 400 (350 rods instead of 400 for piston skirt breakage issues) in the place of the 350 in a 90 blazer i used a performer intake and a tbi adapter plate to convert over from carb 1st im looking for the CFM of a stock tbi 2nd can i swap the 350 tbi with the 454 tbi without a pcm change my idle speed in gear is like 500-550 rpm in gear and will make 200 rpm jumps if i sit too long at a red light other than that engine pulls pretty hard through entire rpm range at wot and holds steady at cruise but i feel like ive lost some power compared to the holley 750 carb previously installed and i know this inst the place but im in looking for a 4l80e 5.7 processor and engine and trans harness for my 4l80 trans swap so i dont have to stick shift the valve body
