Thanks for the reply, I started back at square one and tested all the wires and connections, did alot of searching and it pointed to an ignition issue, I had the module tested and it tested good. So I pulled the dizzy to check the pick up coil, what a mess. I had to use a punch do get the shaft out, it was gummed up, the pick coil looked like it exploded from corrosion and ther was enough rust on the magnets that would not even hold any metal. I started to clean up the shaft but did not like how it spun and found some cracks in the magnets. I bought a reman to replace it with but have not had time to put it in. I kick myself for not checking it when the engine was out. The thought has crossed my mind about just throwing the carb back on.
