Stomis
Professional Amateur
I know the feed and return on the TBI tank units are flare fittings. I was wondering if anyone knew off hand what size they are so I can get AN conversion fittings instead of dropping the tank and then ordering parts.
Russell or some other fitting company part numbers would be even better. Need one for feed and return to -6 to plumb the LS regulator with twist lock.
