TBI & Timing
Miller75
Registered Member
Minnesota
I have a mid to late 80's 350sbc I need to set the timing on.
From the steps I have seen/read I have to do the following:
disconnect the est wire (brown w/black stripe on driver side firewall)
start the truck
set the timing to 0 degrees at idle
shut down
reconnect the est wire
start it back up
I think I'm over thinking the process with the timing light I will be using it has a digital adjustment for advancing the timing do i need to set this to zero also?
thanks
start the truck
shut down
start it back up
thanks
Yes, set your timing light to zero and then adjust the timing to TDC and you're done other than reconnecting the EST wire.
