TBI to CARB
2many
Registered Member
Hopewell,TN
I put 94 TBI motor in my truck but converted to carb (didn't have wiring harness). But my Carb is no good. I want to put a holley on it. I went to summit but way to many to choose from. I want 600cfm electric choke any got any suggestions to help me no which one to choose?:confused:
Thanks:bow:
By the way (I love this site)
i asked the same thing recently and it was pretty much a consistent vote for Q-jet. thats the way i'm going now.
Small primaries will give the most crisp throttle response and economy. Center hung floats make it almost as good off road as fuel injection. Holley's, Edlebrocks (AFB clone) both flood out easily with bumps and weird angles.
Rene
i was told to shy away from SMI. they are all the same basically. just make sure you get one that is sealed on the bolts. they have a leak down issue that i read can be fixed by filling all the recesses for screw heads on the bottom.
JET builds a decent Q-jet, and they build to the intended engine after you provide them all the specs. Saves all the jetting/tuning headaches that can come with a carb.
Rene
