I’m doing some work on this now but I’m in the infancy stages and I haven’t stripped anything yet, my plan is to start at the ECM in the glove box by removing it and move forward with pulling the harness through the firewall and out of the engine bay from there, I’ll then figure out what is attached to the TBI harness and work forward from there with reverse engineering. I want to try to find my own key on power for the distributor without having to hack a bunch of the wiring. From what I understand the TBI stuff is fairly stand alone and most of the harness will come out and not need to be cannibalized, I’m posting mostly for thoughts and opinions on this method and to see if anyone tells me I’m not on track and has a better thought process. There isn’t a lot of support from my searches for removing the TBI unless I’m missing something. I also don’t want to hack up my TBI stuff because one day I’d like to use it or sell it and not trash it.
One of my concerns is the fuel pump power, I plan to use the in tank lift pump and I’m only guessing here but I fear that the pump maybe run off the TBI harness. My thoughts are I’ll either give it power (safely of course) or I may just stick a mechanical pump on the motor and draw through the pump. (I saw at least one instance on the internet where a guy said he’d done this with success.)
