mrdrinksalil
What would make the diagnostic trouble code test not work on a TBI setup? Even if there is no code you should get the 12 flashes correct? I even back pinned to the ECU and tried jumping the ALDL pins A and B. B had continuity to ground. No voltage at all out of the A5 pin (check engine light). Bad Computer?
