moturbopar
Hi I have a 91 suburban 5.7 that is having weird no start problems. Anyways I will start from the beginning. I first noticed I was having problems about 2 to 3 months ago. While driving after 20-30 minutes the suburban would stumble, jerk, just like turning the ignition switch on and off real fast. i tried changing the fuel filter and it seemed to go away for a week or so. It never had any problems dieing or starting. always ran pretty good other than what as listed above. So I kept on driving it. So anyways a week or so after I changed the fuel filter it started acting up again, But this time after 20-30 mins sometimes when I would make a turn it would die or stumble really bad but would fire right back up. So I figured I will try a new fuel filter again, it didn't help a thing. So I figured I would drive it a couple more days to see if I can trouble shoot it. After a couple days the problem seemed to go away, So I started driving it again and had no problems for about a week. Then one day I went out to start it, It would fire then die. So I let it sit till the weekend I go to start it and it fired right up, and was running well, SO I drove it for a day then the next day During a test drive it died during a turn. This time when I went to restart it, it would fire but sounded like only half the cylinders were firing, and would die, It did this about 5 times then started and was able to get home. So today I went out to start it and it wont fire unless I prime It. I can hear the fuel pump run for about 2 seconds. Putting 12v to the fuel pump test wire I can hear the pump run. I am picking up a fuel pump adapter so I can check the fuel pressure, but I am not sure if this is the problem (i unhooked the fuel line and turned the key on and it shot plenty of fuel out, I guess volume is not pressure though). I noticed that no matter what no fuel comes out of the injectors, even when I prime it, Shouldn't (if enough fuel pressure) it start pulsing when the ECM receives an RPM signal? Does the ECM get its injector signal from the ignition module? If so can the Ignition module be bad but still control spark but not the injectors?
Sorry for the long post, but this thing is driving me nuts!
