mckustomfab
1991 Chevy R/V 3500 5.7L tbi. I had swapped in a suburban fuel tank and ran it with no problem. Then I went to work for 5 weeks and when I got home it won't start. And the fuel gauge is showing at the 3 o'clock position.
At first I thought the non starting was because it was low on gas so I added 10gal and still nothing. The fuel pump would not run for the 2sec like it should with the key in the run position. So I pulled the pump and started checking with a multimeter. I have 12v at the fuel pump and I bench tested the pump, it is good. I checked the fuel pump ground and it is good too.
I sprayed a little starter fluid and the engine will run until it is all gone. So this has me scratching my head.
To recap, I have power to the pump, the pump is good and spark at the engine but the pump won't pump... Also I tried to pull the error codes but I'm getting no "check engine" light and when I jump the terminals it doesn't flash anything. Not sure where to start, I don't want to throw parts at the problem so some help would be appreciated.
