thearborbarber
I just put summit aluminum heads on my 91 sub with a tbi. Who would be a good source to have tweak my factory tune and burn a new chip burned?
I have Howell engineering do 2 different ones for me now. They are the original engineering company that designed the system. Ask for Troy, if possible give him airflow numbers for those heads, compression, cam timing.I just put summit aluminum heads on my 91 sub with a tbi. Who would be a good source to have tweak my factory tune and burn a new chip burned?
I got my prom from Troy today. I gave him some rudimentary scan data and wide band info and he hit it out of the park. PE is spot on, BLM and integer is really close and way more power across the board. Thanks again for the tip.
Depends on if $1500 is worth 30hp? In hind sight I'd do a cam with the heads. I use an auto xray ezlink to scan with. Unfortunately I don't have a windows machine old enough to download the data with. I just watch the numbers as I make a run.
