bp71k5
3/4 ton status
So I thought i'd start a new thread to make this easier.
I have a TBI with the following symptoms:
1. Consistant ESC code after engine reached operating temp and driving at speed.
2. An intermittant stumble on hard acceleration in high gear.
3. Pinging when engine is under moderate and high load (doesn't happen at idle).
I did another datalog with the truck not moving, but let it idle and brought it up to 3200 rpm a couple times to let it collect enough data.
Here's the BLM and a screenshot of the sensor data at idle. It seems like my trouble is more when the truck is moving and not at idle since the BLM numbers seem pretty close to ok?
Edit: I do not yet know what the fuel pressure is, but am working on checking that in the next few days.
