Interesting. I'm confused about the purpose of the oil pressure switch. I've read two things: (a) It cuts off fuel if the oil pressure is low, maybe to stop pumping after an accident, and (b) it is a backup so that if the main fuel pump relay fails, fuel will continue as long as there is pressure. In one case it's AND and the other case OR with respect to the main fuel pump relay.Just FYI. I had a weird issue once. TBI wouldn't start, everything checked good. I got pissed one day and just layed on the starter and kept cranking it then she fired up and ran fine. Didnt have too much problems starting it until the next morning then same thing.
Turns out it was a bad Oil Pressure switch. It would not allow the vehicle to start until the oil pressure built up to close the switch.
Anyone know for certain? I suppose I could go find the schematics and figure it out.
Your case would be consistent with (a).
