My 88 k5 will start and run just fine and will idle for a few seconds then it dies, no matter if it is warm or cold,
any one have any ideas?
If it`s not one of the other things mentioned a bad oil pressure senser might do it, the truck starts, and will run for say 15-20 seconds then the computer notices no oil pressure and shuts off. Starts right up and does the same thing over and over, very madening. The sensor is under the distributor next to the back of the firewall too which makes it a bugger to get out. There must be a way to check this for sure though as it`s a pain to do if that`s not the cause. Good luck.
