TBI working erratic 1991 350
monk999
Newbie
nj
Hi new here... 1991 k5 350 tbi.. the pass side injector sprays while running... sounds starved for fuel... driver side is not spraying. I switch plastic connector from top of working to non working side... it sprays... then put non working plastic connector on working injector and IT works... Read a few posts thinking it may be a hose from fuel pump / sending unit to ?? Could it be a gound issue? This problem has come up once or twice, but after a short time running it cleared up... now it wont. Also I just re-grounded the block ground because the truck would not start, with a operating starter, so I was told to re-ground it and that worked... now this. Truck sits a lot and moisture may be an issue if that sounds reasonable. I beleive corrosion caused the block ground to fail.
any help appreciated... hope I posted properly
