You can get a decient ammount of power out of a TBI.
(clicky)
Edelbrock makes a complete power package for them that works pretty good. It has a computer grind Cam, Performer manifold, Headers and Exhaust system.
The stock computer will usually tolerate cam grinds with no more than 214 or less degrees of duration and .450" or less of lift. if you want to put in a bigger cam you will probabally need to get a new chip burned for the computer
If you want to modify the Throttle body for more power. Check out(clicky)
turbocity.com
I'm using a lot of their stuff in my 89 blazer and it works good.
The Ignition system in the TBI Blazers is acually pretty good. You wont gain much by putting in something else. All I'm running is a MSD Blaster coil. It puts out plenty of juice and will run as high of RPM as I have ever wanted to take it to. I had a MSD box in it but I took it out. I really did not notice much diference.
To make it breathe better a K&N cold air intake system will help.
TBIs are a good system. You can make them run good and get pretty good gas milage too.
If you are going to modify and work on a computer controlled vehicle you really need a good scanner. its hard to properly diagnose problems without one.
autoxray.com]makes a very good scanner for around 140 bucks.
