I was gifted a tbss intake for a 5.3 I have. The 5.3 has a truck Norris nsr cam and the rest is stock besides the high volume oil pump. It is from a 2002 avalanche. Dbc with the blue red pcm. The intake has the fuel rail and injectors on it. I will be buying a harness for the motor so my guess is I can buy a harness for a dbc motor if I get a dbc tb. Or buy a dbw harness if I get a pcm and dbw tb and a pedal. Is that train of thought correct? Also can the injectors on the tbss intake be controlled by the blue red pcm? I’m sure this post is repetitive to many ls guys but this is my first swap and I am a lil overwhelmed with information.
