TC EZ rides or HD? 4" lift
howdiy
Fl
I want some springs for my step side. What would you recomend? Stock springs with a shackle flip in the rear and 39.5'' tires
Ez rides are 295# rate and Hd's a 395# rate
Id say my currect superlift 8" lift has 10000 pund rate.
If you hadn't pi**ed me off in your other thread I'd tell you just to order the HD version as the only difference is an extra bottom leaf, then you can take it off and have EZ rides or put it back on and have HDs. That's what I did. Don't forget to get new center pins though when you put it on or off the threads stretch and they are difficult if not dangerous to reuse.
I am actually thinking about becoming a member now :haha:
I just wish it came with free stickers!
Thanks for the reply :bow:
I already knew the answer[since they are so simple ya know] I just wanted an opinion. :wink1::haha:
What?????????????????????? You dont get a CK5 built not bought sticker anymore with a membership?
Ohhh! These are terrible times.
I got 2 stickers when I joined up. Plus a fancy CK5 membership card and secret decoder ring.
When I joined, I didn't even get a reach around, much less some high dollar stickers!!!!
And to think I just ordered 4 stickers 5 minutes ago:D then i find this thread.
The free sticker would put it over the top and I don't think I could hold myself back
I was thinking about buying one of these 2
roadnotca said:
mini_mull said:
the only difference is an extra bottom leaf, then you can take it off and have EZ rides or put it back on and have HDs.quote]Is that true for front and back?
No, the backs are the same with both kits. Check the part number break downs, same numbers.
Glad to hear. And I see you can take it as well as you dish it out, too. You might just fit in well around here after all. :wink1: I had to buy my stickers too. :( There's no such thing as a free lunch.
I must have been posting on a bad day that day lol
I ended up getting the HD's for 250 shipped
I ended up getting some 600* brake duct hose also
There goes 280 dollars :(
mini_mull said:
You're :( will turn to :D when the UPS man shows up. :wink1: What shackle flip are you going to run for the rear?
I made my own. I just modfied the stock mount and strengthend it also. It took a few hours but it was worth it. Sure it won't be the best for flex but there isn't too much trail riding tpye of stuff here.
