tcase replacement options?
ohio k-5
Newbie
marion, ohio
this is not a k5 question, but i just obtained a 92 k3500. it has a 350 4l80e and a borg warner 4401 that came with it. however the tcase has a 6 inch hole in hte case where someone dropped it.
i need to find out what all is compatable with this setup? i've been told the borg is very rare and i probly won't find one. i think it has 2 electric connection on it, if i remember right.
any help will be great
thanks
if I remember correctly there were 3 different BW TCs used. Your tranny should be like a th400 w/ has a 32 spline output, maybe a NV241 would work. I'm not sure about the bolt pattern but you'd probably need the adapter for the 241 vice the BW adapter. It would all come down to the output shaft of the tranny.
The BW4401 isn't too bad to find. Its the 1370 and 4470 that are worse - they are the 11k GVW models and have a magnetic engagement clutch iirc.
An NP241 will bolt onto the same adapter... but now you have a slip-yoke t-case.
