What is best to use the frame mount or torque rod that goes from the tcase to tranny and engine block?
I believe there is a washer that also goes between the support rod and tranny as there is a small gap.
Iirc, it's a stud with a nut made on it so you can torque down and then there's another threaded section that sticks out for the support rod and another nut.
To me, those two pieces serve completely different purposes.
I am not a big fan of the frame mount piece, I believe it over-constrains the system and that's part of why it's common to see broken transmission housings and adapters. Basically, because the mount is so far off of the center of the drivetrain, it has lots of extra leverage and it makes the transfer case mount stiffer than the motor mounts. That's hard on the parts in between (i.e. trans case and adapter). I think there's a reason that GM got rid of them on the later trucks.
The strut rod is a great idea. They tie everything together a little which helps but I think their intent is to resist push from the front driveshaft. When the front is under power, the splines on the driveshaft don't want to slip as easily. So if you're hitting the gas and going over bumps, the driveshaft doesn't want to compress easily and pushes on the t-case. That has potential to break the aluminum t-cases and again, potential to break adapters/transmission cases. I think the strut rod really helps prevent that.
But now as I'm planning to build a doubler setup, I've been looking into how people are mounting their doublers.
And I'm surprised to see that a lot of people are using really tight poly bushings, that are spread out pretty wide, giving it a very high rotational stiffness...
Are there other things that comes into play with a doubler, or how is that?
