BUDDY
SOooooo, I am driving my blazer from las vegas to ft worth. I had just gotten my DIY4X shock relocator installed & because of that, the exhaust pipe had to be cut off so the shock would fit where the exhaust pipe was.
The muffler exits out pointing directly to the rear. I am driving along, everything is going just fine, decide to stop in Williams, AZ to stretch my legs & top off the gas tank.
Go to open the gas cap, twist it off & it literally is STEAMING gasoline vapor & WHISTLING like a tea kettle!!!! HOLY #?*/!
I figured that the exhaust would be dissipated through the turbulence underneath & around the undercarriage of the blazer, but I was WRONG!! It would just build up right in front of the gas tank & it was boiling the gas inside the tank!
I sat around for a good 30 minutes to let this all cool down, left the gas cap off & drove 5 minutes to the only mechanic in town. Who luckily happened to have an exhaust bender, & he made me a little exhaust extension to dump out behind the driver's rear tire.
It's totally fine now, but man!
Moral of the story, exhaust needs to point anywhere but at the gas tank. Duh!!
whew!
Just thought I'd share.
Later,
Buddy
whew!
Later,
Buddy
