tearing my hair out in frustration
bronderslev
denmark
the dumb dane are back....
i got this 6.2 L diesel, and i changed starter on it, no problem and it started right away, then i turn´d it of and now i cant get it to start again... i have already purged the fuel system that wasent it... fore f*** sake i need some help...
I'm asumeing that its turning over right? check your glow pluggs and see if your getting power if you do and you have air ,fuel and a ignition source it should start
it turnes, new glow plugs, new airfilter, and its getting fuel... but still wont start
Check for power at the big pink wire on top of the injection pump when the key is in the run position. If that is OK the shut off solenoid may be sticky. That solenoid is only usually a problem when the motor is hot though.
Rene
