If your putting in new carpet into a daily driver or a restoration type of deal I got a tech tip for ya.
Got to the point in the crew cab build where it was time to cut holes in the carpet for bolt holes and seat belt holes and so on.
Rather than hack at it with razor blade or a scissors of some sort here's what we did.
We grabbed a 1" Hole saw and removed the pilot bit. Chucked the hole saw in a lathe (if you left the drill bit in and chucked it in a drill bit this will still work.) Spin the hole saw and grind the teeth off. (Good to use an old hole saw.) Then with it spinning grind the new toothless edge of the hole saw at an angle to sharpen it. Go over it again with a file to remove the burs inside and out.
Now put in a point sharpened 1/4" rod rather than a drill bit pilot and secure with the set screw.
Locate your bolt hole in the floor and punch the 1/4" sharpened rod pilot through the hole and pull the trigger on your drill. The sharpened hole saw works just like a rotary razor blade. Nice clean hole in the carpet. No snagging or grabbing. You may need to waller the hole saw back and forth to compensate for some of the floor countours.
Should this have been in the tools forum? Eh, whichever.
