B
Bohemian
Guest
i got mixed feelings about using teflon tape on threaded sbc oil galley plugs...
front & back of block and inside lifter valley, etc...
anybody have problems with teflon tape on sbc pipe threaded oil galley plugs?
seems like it'd be ok on outside of block where only one side is exposed to oil, but it seems like may be an issue where both sides of pipe plug are exposed to oil, since you always end up with a little tape exposed on the allen head side, i'm wondering what kind of mayhem that would cause if any came off.
I may be over thinking it, just can't decide wheather to use teflon tape, silicone, loctite or nothing.
thanks in advance.
thanks in advance.
