tell me about this truck
73redblaze
Aptos ca
My brother is thinking of buying this Willys jeep. he hunts and camps all the time so it does not need to be hardcore. anyone know the year or model of this thing?? it has no motor so we are thinking 350/ th350/ np205/np203. we would run a full cab cage and thats about all we would do.
i was serious considering getting one of those as a project for a while but they were too expensive around here. If i had to guess id say mid 40s to early 60s (they didnt change there style much :/). I heard the front clip folds down but idk how that would work as far as all the radiator connections.
Check the frame, I've yet to see an old jeep that the frame wasn't craked in at least a few places,
Plus whats up with the grille/hood thing . Rig looks pretty sketchy. stock axles wont hold up to much more than V6 power so keep that in mind
Thats a project and a half. Like has been said the frames are weak. 203/205 might not fit in between the frame rails. You would have to stretch it out quite a bit to fit it and still have a rear driveshaft. Tons of work
There is so much aftermarket stuff on that, its hard to tell what year or model it actual was.
If you are serious about the running gear you are talking about, do yourself a favor and buy it, take the body off and put it on a K5 chassis and call it a Jeep.
I drove one of those for 10 years as my DD. Also my hunting vehicle, dating vehicle, whatever.
There is nothing I do not know about fixing one of those.
Trust me when I say I can do a complete front wheel bearing change blindfolded.
In mud.
I know, because I did one one night with no flashlight, matches, or moonlight and in the rain . Completely by feel.
Over the years, I completly rewired it, replaced every part of the brake system, pulled the motor and put it back in after a rebuild. Rebuilt the front and rear ends. I had someone else do the transmission, but I changed the needle bearings in the transfer case whenever they got too loud.
Until the wonderful day I found the tapered roller bearing aftermarket kit.
Those little things have a reputation for toughness.
And its earned.
My old Jeep would drive over or through what they are calling Jeeps these days.
But, the main reason they got that rep, was because they were so well balanced. The 134CI Hurricane motor would crank out 90Hp on a good day.
The clutch, transmission and transfer case could take everything it could put out.
And the front and rear ends could handle the torque.
I have often swore that the suspension was designed to break the driver before it broke.
If you started trying to jump ditches or things that might damage the suspension, you got lots of....lets call it feedback, telling you that you were reaching the limits.
You could drop a Buick V6 in it, almost a direct swap. It made a huge difference in the vehicle.
And things did not get too fragile. If you were not too crazy, everything would stand up.
Anything above that, and you were asking for trouble. You would break the transmission, drive shafts, axles, something was going to give. And after you fixed that, something else would give.
I know people do the kind of things you are talking about, but if they keep much of anything original other than the body and maybe the frame, I would be surprised.
