rgretzinger
Hello to all,
I bought my first k-5 2 weeks ago and have been tearing through the engine and interior to get it to where I want it to be, which will take a while. When it comes to the gauges my fuel gauge is pointing at around 4 o'colck which I am assuming is the ground on the fuel sending unit. The temp gaug
e wasn't even hooked up because the wire from the gauge to the temp sending unit had mealted on the old headers. After replacing the old disconnect I hooked it to the temp sending unit and now the gauge reads all the way hot. I was wondering if ya'll have any suggestions or if you think this could be a ground issue with the temp gauge as well. Thanks for any help ahead of time and I look forward to getting to know you on the forum.
Ned
e wasn't even hooked up because the wire from the gauge to the temp sending unit had mealted on the old headers. After replacing the old disconnect I hooked it to the temp sending unit and now the gauge reads all the way hot. I was wondering if ya'll have any suggestions or if you think this could be a ground issue with the temp gauge as well. Thanks for any help ahead of time and I look forward to getting to know you on the forum.Ned
