The coolant temp gauge wasn't working on my Chevy so I started testing to see what was wrong. When I would remove the sender wire with the key on the gauge would bottom out. If I grounded the wire the gauge would max out. So the gauge does work. So I get a new sender for the truck. Engine is a 6.5 turbo diesel, truck is a factory diesel with full gauges for an 82.
The low mark is 100 the high is 240. Well the gauge works now but reading it gives are off. They read high. Truck was at 180, has dual 180 t-stats, but the gauge was reading just below the 240 mark
. I check the actual temp with a temp gun pointing at the t-stat housing. So basically I'm wondering if there is a way to adjust the gauge to read correctly
? Or would that require the gauge being rebuilt or replaced?
