simpleman83
So, I have been having problems with my water temp gauge (i think) because it fluctuates back and forth based on a lot of different things. The most recent thing being that I noticed when I turned the truck off, and the lights were still on, the temp gauge started to climb
..... What does this mean? Would this have something to do with the sending unit? The temp gauge tends to climb if I'm sitting still sometimes and other times not, turning on the heat helps sometimes, others not, when I'm running on the highway the temp is usually way low, other times just where it needs to be. After I shut off the engine from being at running, the gauge climbs then once the key is off, the gauge will go back down. Not sure if this last one is normal or not??? Anybody got any clues? The one that I think is extremely strange is the lights having any affect on the temp gauge....thats just weird!
Ohh and by the way, I installed a new thermostat, water pump, fain clutch, radiator, so its almost 100% the gauge in my estimation.
