My temp gauge doesn’t work, today I took the gauge panel out to see if I could fix it or replace gauges, the new once I have don’t work with the cluser so I put the old one back. I moved the gauge needle to zero and put it back in the truck, turn the ignition on and the needle went from 0-Boiling in 0.5 seconds and doesn’t go back. (Truck has been parked for 2 days so not warm)
Would this be a gauge, wire or sensor problem?
