fireplug
I've only had three GM's but none of them had a temp gauge with actually temps written on it. Only a 'red zone'.
Are you guys posting actual temps using aftermarket gauges or did GM have some with actual temps calibrated on the gauge?
What temp should a properly tuned truck be at? Where would this mark be on a non-calibrated gauge the halfway point?
FI trucks are suppose to run at 195*, since that's the stock t-stat, but I'm not sure what a '76 should run at. BTW, thanks for not hijacking.
