My '88 K5 isn't showing any temp on the guage. I replaced the thermostat thinking it might be stuck open but it didn't fix the problem. Now I need to try swapping out the sending unit but I don't know where to find it. Any help would be appreciated.
its your temp sender. tsu 81 at advanced auto IIRC. or tsu 105 if not. did you ever overheat the engine? that usually fries the sender. i had the same prob. i thought that my new water pump was doing a great job cooling. it was the sender. it should cost around 15 bucks
I tried grounding the sender wire to the block and nothing happened, so i guess the gauge is shot. I'll probably end up replacing the sender unit anyway since it's starting to get pretty nasty looking. A new sending unit, gauge, and coolant flush to go along with the new thermostat and I should have all my bases covered.
