temp sensor wire color?
Disciples Performance
Kelowna BC, Canada
hey guys my 85 k5 lost track of my temp sensor wire so im gonna wire a new one off the fuse block on the engine bay side. Does anyone know what color the wire is and where its situated on the fuse block???:confused:
Cheers
Nick
Temp sensor wire for the temp gauge located in the left head is a green wire.
It should go through the bulk head connector and inside the cab. Just not sure what location the wire is.
Check for continuity with a multimeter. THAT will tell you if the wire is good.
Resistance also changes on the temp sender as temperature changes, the way to test the sender as well.
