Well, after finally lifting the Lowrider 3 inches, I can't decide what to do about shocks. The rear ones are long enough to reach; final measurements will be after the rear D60 goes in, with shock mounts above the axle. The front ones were too short, but they're Bilsteins, I like them, and they're less than a year old. Articulation right now is not a concern, the parking lots here are pretty flat. So I decided to try out F250 shock towers to lower the frame mount 3 inches; here are some pics:
I've mounted them so that the shock is in the middle of it's travel range ( 6 inches total); angle is almost like stock. I figure once I finally make up my mind (and I'm leaning towards Bilstein 5100s), I'll get another set of towers and flip them for long-travel shocks; holes are already there for the mount. Anybody have an idea what overall shock length and travel range I should be looking for - springs are 3 inch TC's up front, back is 2.5 inch shackle flip, tires will be skinny 35's, and I have the longer brake lines in the garage but not installed yet; thanks for suggestions, michael
