Terminator X Harness
pomai
Oahu, Hawaii
What a F_____ mess!!
Any Ideas on how to rout this harness?
I would like to lower it down just above the trans bell housing behind the motor but am worried about wire chafing.
There on the fire wall its secured and wont move but looks like hell!!
They are generic harnesses. If you want it neat and clean, expect to cut and extend and depin and repin.
But also, mine doesn’t look near like that on my k5. I did have to drill a couple of holes in the firewall directly behind the distributor to stick things through.
SBC
Holley Throttle Body #112-587
Holley 550-936 Fuel Injection Kit.
I had to lengthen the Fuel pressure, CTS & TPS wires.
I had to change the MAT & TPS connectors, the connectors that came on the harness was wrong.
Any ideas on lowering the bulk of the harness down over the bell housing area, maybe securing it to one of the bell housing bolts?
Any pictures of harness installations done?
I’m confused how it ended up like this, what kit are you using and what engine?
