Let me start off by saying I understand I shouldn't expect 20mpg from a 3/4 ton truck, but 13-14 mpg seems somewhat realistic after some modifications. It's a 1989 Suburban I bought bone stock. TBI 350, 3.73 gears and a TH400 that averaged around 12mpg with a fairly aggressive driving style, but over the past few months I've done some of the basic mods in hopes of a bit better mileage. I went through and rebuilt the throttle body, replaced all the gaskets and such and put a 1" throttle body spacer on it. I also dumped the old air cleaner setup for a 14" x 3" open element. I have 2 1/4" true duals no cats with 2 chamber mufflers and some full length headers. It's mostly tuned up minus new plug wires, new fuel filter and oil filter, pcv valve, oil change, but it might be worth mentioning I have AC Delco platinum plugs, which I heard bad things about on the TBI engines after my purchase. After all of this I've started averaging 10-11 mpg driving like grandpa! I'm getting worse mileage than before while driving lightly in the name of gas mileage. Best I've been able to get was about 14 and that was on the highway at 55, pretty pathetic. My initial thought was that possibly the heated O2 sensor may have been stuck in open loop due to a loose connection or something but after listening to the engine come up to temp and being able to hear the idle drop that seems unlikely, is there a better way for me to tell? Next I ran 2 cans of seafoam through the fuel system, same results. It might be able to use a set of plug wires but I wouldn't expect that to kill my mileage like it has. I've also thought that possibly my injectors may need service, but while the throttle body was apart they seemed in visibly good condition, as did the whole throttle body, and the spray pattern looks fair. Is there something I'm missing? Could my plugs or injectors be the culprit? Has anyone else experienced a drop in mileage from these mods? Sorry for the long post I've just been battling this for the past month and it's really bugging me.
