Well, my winch worked for BB. Between it working and not working, there was a couple water crossings and very very large splashes.
Could have used it last Sunday
after those splashes.
Anyway, I pushed the switch remote this morning and for a second it worked, then stopped again. I've got nothing, no clicking for either side.
Here's a picture of the solenoids. The red and blue arrows are switched together from the remote. Can I simply jump my battery positive (red wire) to each of these smaller one? Should I hear the relays click, or even use a continuity tester. The circle in the center has wires all connected together. One of these goes back to the remote but doesn't seem to be switched with the button.
after those splashes.Anyway, I pushed the switch remote this morning and for a second it worked, then stopped again. I've got nothing, no clicking for either side.
cause it wont connect the grounds.
Perfect. It's already in the dash and has all the connections. I pulled the Warn switch off, ran the cable into the cab, and connected it to the switch. Towards me is in and away from me is out.
Didn't have to do any cutting, splicing, etc
Granted, it's not fancy hardwired, but it will do the trick. Just plug it in at the start
