TH350 - 205/203 ?
bigmack
Tennessee
I need to replace my TH350 transmission, I have a 205 t-case, I know that my transmission output has 27 splines and uses a drivesleve to mate up to the t-case. My question is does a TH350 for a 203 t-case have the same splines ? If so will it bolt directly to my 205 ? Or will I have to find a TH350 that is for a 205 t-case ?
Anyone out there know about this ? Thanks
'80 K10 350/350/NP205/14B/10B/4.10/4"Lift/Q78-Buckshots
Thanks for the reply, thats what I needed to know.
but the transfer case adapter will not work. you will need the one that is originally for a th350+np205 setup. Does your transfer case that is sitting around have the adapter and sleeve?
mike
