th350 k case & 205
Think you can get the adapter in a flat-rate box? On second thought, is that 205 flange output or slip-yoke? Last Q: what condition is the th350?
Adapter should fit.... 205---rear slipyoke front flange (flate plate 4 bolts?) th350 used in good condition when pulled (replaced with 454&th400) :)
Whole package come's complete as pulled w/ crossmember, shifter, mounts....
Missing the sleeve....coller??? was misplaced.......
Bearing type?? I don't know send me a pic of what one looks like and I'll compare.. Or send me an e-mail and I'll send you some pics!!
Doesn't do me any good without the collar.:doah: Anyway, I'm guessing it's not the bearing type if the collar got misplaced. The bearing type he's referring to has the collar suspended in a bearing in the adapter haousing.
never looked inside the adapter,, just assumed it was a coupler style.....
They are both coupler styles. One is supported on one end by a bearing that is held in by a big snap ring. It would be much harder to "lose" the coupler in the bearing type.
