Hi all,
My daughter demanded that the 70 k5 I'm building for her has an automatic. It was originally a SM420/dana 20 truck I believe. My donor truck was a 78 Chevy 1/2 ton. We did a part time swap into the NP203 and some work on the TH350. I kept the trans/transfer cross member from the 78 and dropped the engine, trans, and transfer case into the K5 frame. Bored some holes for the cross member to mount to the frame. Tonight we tried to put the body back on the frame. The top of the NP203 hits the floor of the body (right at the rear of the trans tunnel opening) keeping the body way too high to mount with new, stock body mounts. It looks to me like the engine/trans/transfer case assembly could be dropped a bit to the rear, but not enough to clear everything. I'm considering dropping the tail end of the powertrain and going with a body lift (which I don't really want to). I guess my question is...Hasn't this been done before, and why do I feel like banging my head on the shop floor because it won't go together? Thanks. Frank
