dessellier93
yes its driver and its about 7 5/8 pretty sure it iswhen i had it on 350 then shaft sticks out about 2in and it bolts to my 241
yes that is what i mean 241 is a 33spline and 350 is 27 anyway for quick fix on that/
ok so input shaft on the 241 i change out right? where might get one at if thats what mean or if one on 350? thanks for all your help to
You need one from 88-98 1/2 ton pickup or 92-98 blazer or suburbanok so what would i ask for like type of t case to get one from or what year?
i found one from a 98 with 27splines but its a 243 would still work??
so having a problem now i finally got the 27spline input shaft for my np241 to bolt to the th350 and there is still about an inch to go before it will bolt together??
like 4 inches but i left it off and the input shaft on tcase is hittin tailshaft where it goes from splines to where thickens a little back down to normal
