Th350 replacement documentation
TJ1978
I have MANY questions
East Valley, Arizona
I’m going to start this thread for all my questions/members answers to document replacement my th350 transmission. I have a few other threads but Id like to keep this part to the replacement process. Ill post pictures along the way.
Today I removed the rear drive shaft. What should be done at this stage? Have it looked at by a shop to make sure its balanced properly?
Also what U joints go in these? The rear just fell apart by my own fault. But I have this stuff down and I want to replace what I need to now. If it looks decent, Id rather just replace it.
What type of bolt is this is this specific one needed? Located on the yoke into rear diff.
I found here this comment: “The 14-bolt (FF) uses a 1350 series u-joint”.
So I need to order 2 of these, correct?
Yeah. Most 14 bolts will still use the stock 1350 series joints. Spicer 5-1350X. To be certain: Measure the caps - 1.188" cap diameter and the span 3.625"cap to cap. There are a lot of weird cross-over joints available, so best to measure what you have right now, never know what you will find under a 45 year old truck.
Also looks like you will want a u-joint strap and bolt kit. Spicer 3-70-28X
I'd take the driveshaft to a driveshaft shop and let them go through it and check it out and do the work. Usually they can rebuild a driveshaft and balance it for like $200.
Just dropped it off at AZ driveshaft. They’re going to look it over and call me back..
Picked up the rear drive shaft. Balanced, weld cleaned up (re-welded) U joints installed and painted. $243
AZ Driveshaft turnaround was quick, 1day.
