audioslave1123
In order to get the transmission into drive I have to slam it back quickly from park, if the trans is in reverse I have to put it back into park then slam it back again, some times its pretty easy, just have to move it quickly, other times it just keeps getting stuck at reverse. I checked the linkage and that seems fine, pulled the linkage off the transmission and tried to shift it directly from there and I had the same problem, so I'm guessing its in the transmission? Any ideas what it could be?
