I haven't posted here yet to break the news but... I bought another k5. It's a 79, Cheyenne. Everything is good on it except for one thing. Something is up either with the shift linkage or something inside the tranny. Here is the problem, if you put the tranny in park or reverse it does not like to come down to drive, it's like sometimes it will fall right back into drive but sometimes it hits a brick wall and you can't move it down past reverse. Everything else below reverse shifts fine, the shifter will run up and down from 1-Neutral every time but if you go above neutral you have to try a few times before it will go back down below reverse. I hope I have explained this well enough. Has anyone ever had this problem, or have any ideas of what it might be. The tranny shifts flawlessly in drive when your driving it, it's just this one problem. Thanks guys.
